The ReadyDATA lets you export an existing volume by exporting the disks on which the volume resides. You can physically insert the disks in other slots of the chassis, in an optional expansion disk array, or in another ReadyDATA that runs the same firmware version.
The share names and all share data, the LUN names and all LUN data, and all snapshots on the shares and LUNs are migrated to the new location, but you need to redefine the following settings:
For shares: User permissions if an Active Directory is not integrated.
For LUNs: iSCSI targets and initiator permissions.
Other than a minimal downtime during the export and import process, users are not affected, provided that you redefine these settings.
To import a volume:
1. Insert all disks on which the volume resides in the slots of a ReadyDATA or optional expansion disk array.
The following occurs:
If the disks are imported successfully, the color of the imported disks in the enclosure turns blue.
The volume is mounted on the ReadyDATA.
2. If an Active Directory is not integrated, reconfigure user permissions for shares.
For more information, see the following support articles:
3. Reconfigure iSCSI targets and initiator permissions for LUNs.
