Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
In certain cases, you can add a disk to a Flex-RAID volume to increase data protection. The following table indicates whether adding a disk for data protection is possible for each Flex-RAID configuration.
Number of Disks per Volume
RAID Level
Can I add a disk to for data protection?
1
RAID 1
Yes. (Additional disk provides redundancy.)
2
RAID 1
No. (Volume protection is already redundant.)
2 or more
RAID 0
No. (RAID 0 does not offer protection.)
3 or more
RAID 5
Yes. (Additional disk provides dual redundancy and converts the volume to RAID 6.)
4 or more
(even number)
RAID 10
4 or more
RAID 6
No. (Volume is already protected with dual redundancy.)
Disks added to a Flex-RAID volume can only be used for protection. They cannot be used for storage (horizontal expansion). If you want to add a disk for increased storage capacity, you must do one of the following:
To add a protection to a Flex-RAID volume:
1. Add a disk to your ReadyNAS storage system.
For more information about how to add a disk to your system, see the hardware manual for your system, which is available at https://support.netgear.com/product/ReadyNAS-OS6.
2. Select System > Volumes.
The new disk is displayed in the enclosure graphic and is colored black.
3. Select the new disk from the enclosure graphic.
4. Click the Add Parity button next to a volume that allows or requires additional protection.
A pop-up screen appears and asks you to confirm your decision.
5. Click the Yes button.
Your data protection is increased in the background while you continue to use your storage system.
You can continue to use your ReadyNAS system while the extra disks are incorporated in the background. The process of increasing data protection can take several hours. If you set up email notifications for your system, you receive an email message when the process finishes. For more information about alert notifications, see the What are system alerts and how do they work with my ReadyNAS OS 6 storage system?
Last Updated:07/07/2025 | Article ID: 23138
Our team is here to help!
Phone
Chat
Email
