Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
This article addresses common problems with wireless networks sorted by the type of symptoms you are experiencing.
Symptoms:
  • Unable to connect to wireless due to forgotten wireless password
  • Failed to authenticate due to wrong password
  • Can't find or remember the wireless network name or SSID
  • Can't connect to my wireless network
For possible resolutions, please see one of the following:
Symptoms:
  • Unable to see the router's wireless network
  • Wireless network is not detected
  • Can't see my router SSID
  • Having problems enabling the wireless radio
For possible resolutions, please see the following:
Symptoms:
  • Can't add a device to my wireless network
Symptoms:
  • Validation and Certificate error with Windows XP/Vista
  • Unable to attain maximum wireless speed using a NETGEAR USB wireless adapter
Symptoms:
  • Your wireless network is not secure
Symptoms:
  • Low wireless signal
  • Short wireless range
  • Intermittent wireless connection
Last Updated:07/07/2025 | Article ID: 13205
Our team is here to help!
Phone
Chat
Email
