Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
2 people found this helpful in last 30 days
Your NETGEAR router has internal wireless radios that broadcast WiFi signals. By default, they are turned on so that you can connect wirelessly to the router. When the wireless radios are turned off, you can still use an Ethernet cable for a LAN connection to your router.
You can turn the wireless radios on and off for each of your router's wireless bands from the router web interface. If you only want to turn off a specific band, you can do so. For more information about wireless bands, see What is the difference between 2.4 GHz, 5 GHz, and 6 GHz wireless frequencies?
You can also turn the wireless radios on and off by using your router’s WiFi button icon (WiFi On/Off) button. For more information, see How do I turn the wireless radios on and off on my NETGEAR router using the WiFi On/Off button?
If you use the router web interface to turn the wireless radios off, you cannot turn them back on using the WiFi On/Off button. You must use the router web interface to turn the wireless radios on.
To turn your NETGEAR router’s wireless radios on and off router using the router web interface:
  1. Launch a web browser from a computer or mobile device that is connected to your router's network.
  2. Enter http://www.routerlogin.net.
    A login window opens.
  3. Enter the router user name and password.
    The user name is admin. The password is the one that you specified the first time that you logged in. The user name and password are case-sensitive.
    The BASIC Home page displays.
  4. Select ADVANCED > Advanced Setup > Wireless settings.
    The Advanced Wireless Settings page displays.
  5. Scroll down to the wireless band to turn off.
    For example, to turn the wireless radio on or off for the 5 GHz band channel, scroll down to the 5GHz (a/n/ac/ax) section.
  6. Select or clear the Enable Wireless Router Radio check box.
    For each band, selecting the check box turns the wireless radio on, and clearing the check box turns the wireless radio off.
  7. Click or tap the Apply button.
    Your wireless radios are turned on or off.
Last Updated:07/07/2025 | Article ID: 24101
This article applies to:
Recently Viewed Articles
    Read this article in another language:
    Our team is here to help!
    Phone
    Chat
    Email
