Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
NETGEAR Smart Switches support Simple Network Management Protocol (SNMP). A trap is an SNMPv1 or SNMPv2 message that is sent to a host (such as a computer or server) when an event occurs on the switch. A trap flag is a condition or event that triggers the trap. An example of a trap flag is an event involving authentication, such as when a user attempts to access the switch UI but does not provide a valid user name and password. You can enable or disable individual trap flags.
Before a host can receive a trap, you must add a community and trap configuration that defines the host.
For information about enabling an SNMP trap on a Smart Switch using a Smart UI, see How do I enable a Simple Network Management Protocol (SNMP) trap on a Smart Switch with the Smart UI?
On a Smart Switch with a traditional UI, to add a community, configure a trap configuration for a server with IP address 10.100.5.17, and enable a trap flag for a Link Up/Down event:
  1. Connect your computer to the same network as the switch.
    You can use a WiFi or wired connection to connect your computer to the network, or
    connect directly to a switch that is off-network using an Ethernet cable.
  2. Launch a web browser.
  3. In the address field of your web browser, enter the IP address of the switch.
    If you do not know the IP address, see How do I discover a NETGEAR Smart Switch.
    The Device UI login page displays.
  4. Enter one of the following passwords:
  • Enter your device admin password.
  • If you previously managed the switch through the Insight app or Cloud portal,
    enter the Insight network password for the last Insight network location.
  1. Click the Go button.
    The System Information page displays.
  2. Select System > SNMP > SNMP V1/V2 > Community Configuration.
  3. Set up an SNMP community by completing the following settings:
  • Management Station IP: Type 10.100.5.0.
  • Management Station IP Mask: Type 255.255.255.0.
  • Community String: Type SNMP-community as the name string.
  • Access Mode: Select ReadWrite from the menu.
  • Status: Select Enabled from the menu.
  1. Click the Add button.
    Your settings are saved.
  2. Select System > SNMP > SNMP V1/V2 > Trap Configuration.
  3. Set up a trap configuration by completing the following settings:
  • Recipients IP: Type 10.100.5.17.
  • Version: Select SNMPv2 from the menu.
  • Community String: Type SNMP-community.
  2. Select System > SNMP > SNMP V1/V2 > Trap Flags.
  3. Set the trap flag by selecting the Link Up/Down Enable radio button.
    This radio button is selected by default.
  4. Click the Apply button.
Last Updated:08/27/2025 | Article ID: 000067291
Our team is here to help!
Phone
Chat
Email
