Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
You can discover your NETGEAR Smart Switch or Easy Smart Managed Switch using the free NETGEAR Discovery Tool (NDT) application.
To download the NDT and discover your switch:
  1. Visit the NETGEAR Discovery Tool page.
  2. Click the Downloads button.
  3. Click the Linus, Mac, or Windows version, depending on your computer's operating system.
  4. Click the Download button for the selected version.
    The NDT download begins.
  5. Temporarily disable the firewall, Internet security, antivirus programs, or all of these on the computer that you use to configure the switch.
  6. Unzip the NDT files, and click or double-click the .exe file to install the program on your computer.
    You might see the tool icon appear on your Mac dock or Windows desktop.
  7. Reenable the security services on your computer.
  8. Power on the switch.
    The DHCP server assigns the switch an IP address.
  9. Connect your computer to the same network as the switch.
    You can use a WiFi or wired connection. The computer and the switch must be on the same Layer 2 network.
  10. Open the NDT by double-clicking the NETGEAR Discovery Tool icon on your desktop.
    The initial page displays a menu and a button.
  11. From the Choose a connection menu, select the network for the switch.
  12. Click the Start Searching button.
    The NDT displays the IP addresses of the switches that it discovers.
  13. Click the ADMIN PAGE button next to your switch.
    The page that displays depends on your type of switch.
If the NDT does not discover your switch, try the following:
  • Make sure that your switch is in the same broadcast domain as your computer.
  • Connect your computer directly to your switch.
  • Temporarily disable any firewall or security programs on your computer.
  • Temporarily disable the wireless connection on your computer.
  • Reboot your switch.
  • Reset your switch to factory default settings.
Last Updated:07/07/2025 | Article ID: 30915
This article applies to:
Recently Viewed Articles
    Read this article in another language:
    Our team is here to help!
    Phone
    Chat
    Email
