Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
NETGEAR Smart Switches support Simple Network Management Protocol (SNMP). A trap is an SNMPv1 or SNMPv2 message that is sent to a host (such as a computer or server) when an event occurs on the switch. A trap flag is a condition or event that triggers the trap. An example of a trap flag is an event involving authentication, such as when a user attempts to access the switch UI but does not provide a valid user name and password. You can enable or disable individual trap flags.
Before a host can receive a trap, you must add a community and trap configuration that defines the host.
For information about enabling an SNMP trap on a Smart Switch using a traditional UI, see How do I enable a Simple Network Management Protocol (SNMP) trap on a Smart Switch with a traditional UI?
On a Smart Switch with a Smart UI, to add a community, configure a trap configuration for a server with IP address 10.100.5.17, and enable a trap flag for a Link Up/Down event:
  1. Connect your computer to the same network as the switch.
    You can use a WiFi or wired connection to connect your computer to the network, or
    connect directly to a switch that is off-network using an Ethernet cable.
  2. Launch a web browser.
  3. In the address field of your web browser, enter the IP address of the switch.
    If you do not know the IP address, see How do I discover a NETGEAR Smart Switch.
    The Device Admin Password page displays.
  4. Enter one of the following passwords:
  • Enter your device admin password.
  • If you previously managed the switch through the Insight app or Cloud portal,
    enter the Insight network password for the last Insight network location.
  1. Click the Login button.
    The Dashboard page displays.
  2. Select System > Protocols > SNMP > Community Configuration.
  3. Click the Add New button.
  4. Set up an SNMP community by completing the following settings:
  • Management Station IP: Type 10.100.5.0.
  • Management Station IP Mask: Type 255.255.255.0.
  • Community String: Type SNMP-community as the name.
  • Access Mode: Select ReadWrite from the menu.
  • Status: Select Enabled from the menu.
  1. Click the Save button.
    Your settings are saved.
  2. Select System > Protocols > SNMP > Trap Configuration.
  4. Set up a trap configuration by completing the following settings:
  • Recipients IP: Type 10.100.5.17.
  • Version: Select SNMPv2 from the menu.
  • Community String: Type SNMP-community.
  2. Select System > Protocols > SNMP > Trap Flags.
  3. Set the trap flag by clicking the Link Up/Down toggle so that it displays purple and positioned to the right.
    This is the default setting for the Smart Switch.
  4. Click the Apply button.
Last Updated:08/27/2025 | Article ID: 000067289
Our team is here to help!
Phone
Chat
Email
