Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
Before you can set up your Orbi Pro WiFi System to work with Insight, you must set up your Insight account and create an Insight network location. For more information, see the following knowledge base articles:
Then, decide whether you want to use your Orbi Pro as a router or as an access point:
  • If you do not have a router or you want to replace your current router, use your Orbi Pro as a router.
  • If you already have a router, but you want to use your Orbi Pro to extend the router’s range, use your Orbi Pro as an access point.
To set up your Orbi Pro WiFi System to work with Insight:
  1. Set up your Orbi Pro using the instructions in the included Installation Guide or in this knowledge base article: How do I set up my Orbi Pro WiFi 6 network using Insight?
If you want to use Orbi Pro as an access point, you can connect Orbi Pro to your router or to a switch in your network. You only need to connect the Orbi Pro router directly to your modem if you want to use it in router mode.
  1. If you have add-on Orbi Pro satellites, sync them to your Orbi Pro router.
    For more information, see How do I sync an add-on satellite with my Orbi Pro router?.
  2. Make sure that your Orbi Pro is in the correct mode: router mode or AP (access point) mode.
    For more information, see How do I configure my Orbi router to act as an access point?.
  3. Place your Orbi Pro router and satellites to ensure maximum WiFi coverage.
    For more information, see Where should I place my Orbi Pro devices?.
  4. Follow the instructions in this article to add your Orbi Pro to an Insight network location: How do I discover, add, and register switches, access points, and Orbi Pro WiFi Systems in Insight?.
Last Updated:07/07/2025 | Article ID: 000053872
This article applies to:
Recently Viewed Articles
    Read this article in another language:
    • Deutschland (Deutsch)
    • United States (English)
    • 日本 (日本語)
    Our team is here to help!
    Phone
    Chat
    Email
