Before you can set up your Orbi Pro Wifi 6 to work with Insight, you must set up your Insight account and create an Insight network location. For more information:
To set up your Orbi Pro WiFi 6 using the Insight app, see How do I discover add and register switches access points and Orbi Pro WiFi Systems in Insight?.
- Power on your Orbi Pro WiFi 6 router.
- Connect your computer to the Orbi Pro router with an Ethernet cable or WiFi
connection.
If you connect using a WiFi connection, use the preassigned WiFi network name (SSID) and password on the label of the Orbi router to connect to the Orbi WiFi network.
- Launch a web browser.
- Log in to your Insight Cloud Portal.
- If you have an Insight Pro account, select an organization.
- Select a location.
- Click the + icon.
- Enter the serial number of the Orbi Pro WiFi 6 router.
- Click Go.
- To rename your device to differentiate from your other devices, you can do so under the Device Name section.
- Click Next.
- Select Devices.
- Verify if the Orbi Pro WiFi 6 router is added to your location.
Your Orbi Pro WiFi 6 router might appear as Device is rebooting for 2-5 minutes while the settings are being applied. After the reboot, you Orbi Pro WiFi 6 router displays as Connected.
To set up your SSID, see How do I set up the SSID on my Orbi Pro WiFi 6 using Insight Cloud Portal?.
You now can use Insight to manage your Orbi Pro WiFi 6 network.
