To display and manage the system logs:
Select System > Info > Logs.
The following figure shows only the Logs section on the Info screen:
You can download the logs, clear the logs onscreen, and configure the logs:
Download the logs. Click the Download Logs button to download a zipped file with all log files to your browser's default download location. The default name of the zipped file is System_log_<host name>.zip, in which <host name> is the host name of the ReadyDATA. For more information, see the How do I change the host name on my ReadyDATA storage system?
Clear the logs. Click the Clear Logs button. The log entries onscreen are cleared but the log files remain intact.
Configure the logs. Under Records, select which message levels and categories are logged. These selections affect the system logs, alerts, SNMP traps, and onscreen messages.
Message levels. By default, the Errors, Warnings, and Info check boxes are selected, causing errors, warnings, and informational messages to be logged. You can clear any check boxes.
Message categories. By default, messages for all categories are logged. From the drop-down list, you can select to log individual categories only: System, Disk, Volume, Share, Account, or Miscellaneous.
Use the navigation box in the lower left of the screen to view additional messages onscreen.
