Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
WiFi 6E builds on the existing WiFi 6 (802.11ax) standard. WiFi 6E offers all of the cutting-edge features of WiFi 6 and allows access to a new 6 GHz wireless band.
The Intel AX210 WiFi chipset is the most common network adapter hardware with WiFi 6E support. Multiple vendors sell WiFi adapters that use the Intel AX210 chipset; if you have a WiFi 6E adapter in your computer, it probably uses the Intel AX210 chipset, even if it was sold under a different brand name.
If you have an Intel AX210 WiFi 6E adapter, and you are having problems connecting to your WiFi 6E router, mesh system, or access point, try the following:
Make sure Windows 11 is installed and up-to-date
Microsoft only supports WiFi 6E in Windows 11. If your computer has Windows 10 installed, it cannot access the 6 GHz band. If your computer has Windows 11 installed, and it cannot connect to your WiFi 6E router, make sure that you have installed all available Windows updates for your computer. For more information about 6 GHz WiFi requirements on Microsoft Windows PCs, see Intel's How to Enable Wi-Fi 6E/ 6GHz Band Using Intel® Wi-Fi 6E (Gig+) products support article.
Install the latest Intel AX210 WiFi adapter driver
Intel regularly releases driver updates to fix bugs and resolve compatibility issues. We recommend that you use AX210 driver release 22.70 or newer, as the 22.70 driver can see and connect to the 6 GHz band successfully without registry changes. For more information, see Intel's Wi-Fi 6E AX210 Latest Drivers & Software page.
For more information:
Last Updated:07/07/2025 | Article ID: 000064669
This article applies to:
Recently Viewed Articles
    Read this article in another language:
    Our team is here to help!
    Phone
    Chat
    Email
