Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
WiFi speed tests are generally accurate, but many factors can affect WiFi speed test results.
Speed test results might vary depending on factors like where your mobile device is in relation to your router or mesh system and how many connected devices are actively using bandwidth. If the device performing the speed test is close to your router or mesh system and there are no other devices using bandwidth, you will get better results than if you are far away and other devices are using network resources.
Your results can also vary depending on the server your device is using to perform the speed test. Your distance from the speed test company’s server and how much traffic the speed test company’s server is receiving affect your speed test results. For example, if you live in San Francisco, your speed test results using a server in San Francisco will differ from your results using a server in Los Angeles, and the amount of traffic each server gets might also change the results.
If your speeds are still below your expectations, you might be experiencing a problem with your Internet service provider (ISP) or the service line entering your home. Contact your ISP to continue troubleshooting.
For more information:
Last Updated:07/07/2025 | Article ID: 000037823
This article applies to:
Recently Viewed Articles
    Our team is here to help!
    Phone
    Chat
    Email
