Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
6 people found this helpful in last 30 days
Resetting your Orbi WiFi system to factory default settings erases personalized settings such as your network name (SSID) and password.
If you have an active NETGEAR Armor or NETGEAR Smart Parental Controls subscription associated with your Orbi, you must manually reactivate Armor or Smart Parental Controls (SPC) services after performing a factory reset. To reactivate, launch the Orbi app and tap the Armor or SPC tile, then follow the prompts.
To reset your Orbi WiFi system to factory default settings:
  1. Make sure your Orbi device is powered on.
  2. Using a paper clip or similar object, press and hold the Reset button until the Power LED on your Orbi device blinks amber.
    Note: If you are resetting a wall-plug satellite, the ring LED blinks amber.
    Your Orbi device is reset.
After you reset your Orbi WiFi system, set it up again using the Orbi app or a web browser.
For more information, see the following knowledge base article: How do I set up my Orbi WiFi System?
Last Updated:11/18/2025 | Article ID: 000034592
This article applies to:
Recently Viewed Articles
    Read this article in another language:
    Our team is here to help!
    Phone
    Chat
    Email
