Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
Most NETGEAR products use a power adapter (also known as a power supply or AC/DC adapter) that connects the device to a wall outlet. The power adapter converts your wall outlet’s power to the power required by your product.
Each NETGEAR product's power adapter has the correct input power, output power, and plug polarity for your device. We strongly recommend that you only use the power adapter that is included with your NETGEAR product. If you use the wrong power adapter, your NETGEAR product might be damaged and unsafe to operate after receiving power that it is not rated to handle. If you need a replacement power adapter for your product, contact NETGEAR Support.
Your NETGEAR product’s power adapter might be warm to the touch when plugged in. This is normal; when power is converted from your wall outlet to the type required by your device, some of that power is naturally lost to heat.
For more information, see How much power does my NETGEAR router use?
For information about USB cables and power adapters for use with NETGEAR mobile hotspots and mobile routers, see Third-party USB cable and power adapter compatibility with NETGEAR mobile hotspots and mobile routers.
Last Updated:12/06/2025 | Article ID: 000028995
This article applies to:
Recently Viewed Articles
    Read this article in another language:
    Our team is here to help!
    Phone
    Chat
    Email
