We recommend purchasing an official NETGEAR Nighthawk Mobile Fast Charger, which is compatible with all current NETGEAR mobile hotspots.
The NETGEAR warranty does not cover damage to the NETGEAR product caused by non-NETGEAR batteries or chargers.
The power adapter and USB cable that you use with your mobile hotspot must meet certain standards to provide sufficient power for device charging and Plugged-In Mode.
Depending on the region where you purchased your hotspot, it includes a Quick Charge 2.0-certified or Quick Charge 3.0-certified power adapter and a USB 3.2 Type-A to Type-C cable. We recommend that you use the included USB cable and power adapter with your hotspot for best performance. The M3 models come with a USB cable to charge the battery; a power adapter is not required.
NETGEAR cannot guarantee the performance of specific third-party power adapters or USB cables with your hotspot. However, high quality third-party power adapters and USB cables that meet the following standards should provide similar performance to the included parts:
- Quick Charge 2.0 power adapter with USB 3.2 Type-A to Type-C cable
- Quick Charge 3.0 power adapter with USB 3.2 Type-A to Type-C cable
- Quick Charge 4.0 power adapter with USB 3.2 Type-C cable
- USB Power Delivery 3.0 power adapter with USB 3.2 Type-C cable
For more information:
