固件要求
| 型号 | 固件版本 |
| M4300系列交换机 | 12.0.9.3 及以上本 |
一、通过 Console 口设置(CLI 方式)
- 请使用 Console 电缆(产品随设备附带)连接交换机与PC
- 使用 mini USB Console 接口(第一次需安装驱动)
- 使用 RJ45 RS232 Console 线(需要使用 USB 接口转串口的转接线)
- 运行超级终端程序,建立新的端口基本属性(不同终端介面会有差异)
- 每秒位数(B):115200
- 数据位(D):8
- 奇偶校验(P):无
- 停止位(S): 1
- 数据流控制(F):硬件
- 正确的基本连接准备设置完毕后,就可以在超级终端内看见 M4300 系列交换机的命令行(CLI)配置界面
- 管理员帐号用户名(缺省):admin
- 管理员帐户口令(缺省):初始配置需设置一个新密码
- 登陆进入 M4300 系列交换机配置管理 VLAN1 IP 地址
使用 Ezconfig 向导,直接配置 VLAN 1 的地址,并开启三层路由(配置命令及步骤如下图所示)
User:
User:admin
Password:*********
(M4300-16X) >enable(M4300-16X) #ezconfig
EZ Configuration Utility
Hello and Welcome!
This utility will walk you thru assigning the IP address for the switch
management CPU. It will allow you to save the changes at the end. After
the session, simply use the newly assigned IP address to access the Web
GUI using any public domain Web browser.
Do you want to change the admin password (password length should vary in a range of 8 - 64 characters) (Y/N/Q)? N
//是否设置管理密码,选N表示不设置
The 'enable' password required for switch configuration via the command
line interface is currently not configured.
Do you want to assign it (password length must be in range of 8 - 64 characters) (Y/N/Q)? N
//是否设置控制台特权密码(enable密码),选N表示不设置
Current IPv4 Management Interface: vlan 1
Do you want to set new Management VLAN ID (Y/N/Q)?NAssigning an IPv4 address to your switch management
Current IPv4 Address Configuration
Management VLAN ID: vlan 1
IPv4 Address Assignment Mode: None
IPv4 Address: 0.0.0.0
Subnet Mask: 0.0.0.0
Gateway: 0.0.0.0
Routing Mode: EnableIPv4 address is not assigned. What do you want to do?
C - Configure IPv4 address manually.
D - Assign IPv4 address for the switch using DHCP Mode(current IPv4 address will be
lost).
N - Skip this option and go to the next question.
Q - Quit.
? - Help.
(C/D/N/Q/?)? C //按C设置交换机VLAN1 IPIPv4 Address: 192.168.1.100
Network Mask: 255.255.255.0
Gateway: 192.168.1.1
Do you want to enable global routing (Y/N)? Y //是否启用全局路由Current IPv6 Management Interface: (not configured)
Do you want to set new IPv6 Management VLAN ID (Y/N/Q)? N //是否配置IPv6的管理IP地址Do you want to apply and save the changes (Y/N)? Y // 保存设置
Config file 'startup-config' created successfully .
The configuration changes have been applied and saved.
Please enter 'show running-config' to see the final configuration.Thanks for using EzConfig!
(M4300-16X) #
二、通过 OOB 接口设置(WEB 方式)
- 通过交换机自带的OOB(带外管理接口),使用网线连接 PC 的网口
OOB 接口默认管理IP: 192.168.0.239
- 设置 PC 的 IP 地址为 192.168.0.10(与 OOB 同一子网即可)
- 通过默认 IP 192.168.0.239 登录交换机的管理页面,
- 密码:默认密码为空
输入管理员用户admin,按 Login 按钮,提示设置新的密码,按要求输入设置新密码即可。
设置成功后,用管理员 admin 帐号,和新设置的密码,登入交换机 WEB 管理页面。
注意:WEB 管理方式,也可通过 VLAN1 的 IP 地址进行管理,第一步配置好后,通过 PC 用网线连接交换机以太网接口,PC 配置与 VLAN1 同一子网的 IP 地址,即可。
