Enterprise AV Home WiFi Mobile Wifi Support
Bug Fixes
  • Fixes HTTP auth (CSRF) issue
To Install
Note: To avoid wireless disconnect issue during the firmware download process, NETGEAR recommends that firmware upgrade be performed on a computer with wired connection.
  1. Write down all the settings which you changed from the default values, since you may need to re-enter them manually.
  2. Using the Download Link below, download and extract the new firmware to a convenient place such as your desktop.
    Download Link:
    All regions except North America, United Kingdom & Australia: http://www.downloads.netgear.com/files/GDC/D500/D500-V1.0.0.20_1.0.1_PE.zip
    For India: http://www.downloads.netgear.com/files/GDC/D500/D500-V1.0.0.20_1.0.1_IN.zip
  3. Log in to the router using a Web browser. The URL is http://www.routerlogin.net.
  4. Click ADVANCED tab > Administration > Firmware Upgrade.
  5. Click Browse and find the file you just downloaded.
  6. Click Upload. Do not interrupt the upgrade while the router does this step.
Обновлено:10/17/2025 | Article ID: 30151
Недавно просмотренные статьи
    Our team is here to help!
    Phone
    Chat
    Email
