APM402XLは、2つのQSFP+ポートをもつM4300-96X用の追加カードです。
NETGEARではQSFP+トランシーバーを販売しておりませんが、以下の動作確認が取れている他社製品のリストをご参考にお使いください。
| メーカー名 | 製品名 |
| Cisco | 40GBASE-SR4 QSFP+ transceiver module for MMF, 4-lanes, 850-nm wavelength, 12-fber MPO/MTP connector (QSFP-40G-SR4) |
| 40GBASE-SR4 (IEEE 802.3ba Spec.) QSFP+ transceiver module for MMF, 4-lanes, 850-nm wavelength, 12-fber MPO/MTP connector (QSFP-40G-SR4-S) | |
| 40GBASE-LR4 QSFP 40G transceiver module for Single Mode Fiber, 4 CWDM lanes in 1310nm window Muxed inside module, Duplex LC connector, 10km, 40G Ethernet rate only (QSFP-40G-LR4-S) | |
| 40GBASE-CSR4 QSFP+ transceiver module for MMF, 4-lanes, 850-nm wavelength, 12-fber MPO/MTP connector, 300 m reach with OM3 fber (QSFP-40G-CSR4) | |
| 40G QSFP Bi-Directional transceiver module, Duplex Multi-mode Fiber, LC Duplex connector, 100m reach with OM3 fiber (QSFP-40G-SR-BD) | |
| 40GBASE-CR4 QSFP+ direct-attach copper cable, 1 meter passive (QSFP-H40G-CU1M) | |
| 40GBASE-CR4 QSFP+ direct-attach copper cable, 3 meter passive (QSFP-H40G-CU3M) | |
| 40GBASE-CR4 QSFP+ direct-attach copper cable, 5 meter passive (QSFP-H40G-CU5M) | |
| 40GBASE-CR4 QSFP+ direct-attach copper cable, 7 meter active (QSFP-H40G-ACU7M) | |
| HPE | X140 40G QSFP+ MPO SR4 Transceiver (JG325A) |
| X140 40G QSFP+ LC LR4 SM 10km 1310nm Transceiver (JG661A) | |
| X140 40G QSFP+ LC BiDi 100m MM Transceiver (JL251A) | |
| X240 40G QSFP+ to QSFP+ 1m Direct Attach Copper Cable (JG326A) | |
| X240 40G QSFP+ to QSFP+ 3m Direct Attach Copper Cable (JG327A) | |
| X240 40G QSFP+ to QSFP+ 5m Direct Attach Copper Cable (JG328A) |
前回の更新:07/07/2025
記事ID: 000055102
