The amount of power that your Orbi WiFi System uses depends on the specific models in your system and whether they are idle (no devices connected) or in use. To calculate how much power your Orbi WiFi System is using, add the watts of each product in your system based on their current state.
For example, if you have an RBRE960 and three RBSE960 satellites that are all turned on and idling, your Orbi WiFi System is using 44.1 Watts.
If you are not sure which models are in your Orbi WiFi System, see Which Orbi routers and satellites come with which Orbi WiFi System?.
The following table lists the amount of power each Orbi model uses in each state.
| Model | Off | Idle | In Use | Maximum Connections |
| CBR40 | 0.1 W | 13.06 W | 13.06 W | 35.76 W |
| CBR750 | 0.1 W | 16.14 W | 16.14 W | 35.53 W |
| LBR1220 | NA | 4.62 W | 5.67 W | 9.61 W |
| LBR20 | 0.24 W | 4.94 W | 8.92 W | 15.12 W |
| NBR750 | NA | NA | NA | 21.36 W |
| RBR10 | NA | 4.62 W | 5.67 W | 9.61 W |
| RBR20 | 0.24 W | 4.94 W | 8.92 W | 15.12 W |
| RBR350 | NA | 6.5W | 9.2W | 12.96W |
| RBR40 | 0.32 W | 7.8 W | 10.2 W | 18.36 W |
| RBR50 | 0.1 W | 6.1 W | 10.5 W | 34.68 W |
| RBR50v2 | 0.249 W | 7.7 W | 8.5 W | 27.84 W |
| RBR750 | 0.02 W | 6.3 W | 10.1 W | 22.4 W |
| RBR760 | NA | 6.3 W | 8.6 W | 26.6 W |
| RBR840 | 0.03 W | 8.3 W | 12.3 W | 37.8 W |
| RBR850 | 0.03 W | 8.3 W | 12.3 W | 37.8 W |
| RBR860/B | 0.03 | 8.3 W | 12.3 W | 37.8 W |
| RBRE950 | 0.02 W | 7.4 W | 13.4 W | 38 W |
| RBRE960/B | 0.02 W | 7.4 W | 13.4 W | 38 W |
| RBS10 | NA | 4.62 W | 4.86 W | 9.12 W |
| RBS20 | 0.24 W | 4.94 W | 8.92 W | 15.12 W |
| RBS350 | NA | 6.5W | 9.2W | 12.96W |
| RBS40 | 0.32 W | 7.8 W | 10.2 W | 18.36 W |
| RBS40V | 0.08 W | 5.64 W | NA | 28.35 W |
| RBS50 | 0.1 W | 6.1 W | 10.5 W | 34.68 W |
| RBS50v2 | 0.249 W | 7.7 W | 8.5 W | 27.84 W |
| RBS50Y | 0.16 W | 5.2 W | 7.2 W | 24.6 W |
| RBS750 | 0.02 W | 6.3 W | 10.1 W | 22.4 W |
| RBS760 | NA | 6.1 W | 7.7 W | 25.5 W |
| RBS840 | 0.03 W | 8.3 W | 12.3 W | 37.8 W |
| RBS850 | 0.03 W | 8.3 W | 12.3 W | 37.8 W |
| RBS860/B | 0.03 W | 8.3 W | 12.3 W | 37.8 W |
| RBSE950 | 0.02 W | 7.3 W | 13.4 W | 37.9 W |
| RBSE960 | 0.02 W | 7.3 W | 13.4 W | 37.9 W |
| RBSE960B | 0.02 W | 7.3 W | 13.4 W | 37.9 W |
| RBW30 | 0.06 W | 5.2 W | 8.2 W | 14.28 W |
