Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
A Wireless Distribution System (WDS), also known as a wireless bridge, is a feature that enables interconnection between wireless access points to extend or expand a wireless network. It also allows for multiple sites to join networks together without the need of a wired backbone. On Netgear ProSafe access points WDS is supported in a Point-to-Point or Point to Multi-Point configuration.  A Point-to-Point setup allows for two LAN segments joining together wirelessly, a Point to Multi-Point configuration allows for one base Point to connect to four remote Points, all four points connect back to the base point and not to each other. In ProSafe access points WDS is referred to as a Wireless Bridge.
The following is a list of ProSafe access points and the models which are interoperable for creating a wireless bridge (WDS):
WNAP210v2
WNDAP320
WNDAP350
WNDAP360
WNDAP660
WNDAP620
WND930
The models in the list above are not interoperable with any AC model access point for configuraing a wireless bridge.
WAC120 - the WAC120 model can only be used in WDS configuration with other WAC120's, it is not interoperable with other models.
WAC720, WAC730 - the WAC720 and WAC730 models can only be used in WDS configuration with other WAC720 or WAC730's, they are not interoperable with any other models.
Please proceed for a list of Requirements and configuration of a Wireless Distribution System (WDS) on ProSafe access points
Last Updated:07/07/2025 | Article ID: 30984
Our team is here to help!
Phone
Chat
Email
