Bug Fixes:
- Extended SSL VPN ActiveX certificate expiring. ,
- Fixed e-mails that were being sent by UTM were being marked as spam and the mail sender name "FROM" was being eradicated. ,
- Fixed the email does not work: when IMAP and IMAPS scanning is enabled, send email by Google mail from LAN host and receive email by Google mail does not always working. ,
- Fixed UTM does not work with ReadyNAS v 6.1.8. ,
- Fixed can't receive hotmail email when SMTP scanning enabled. ,
- Fixed the issue that IMAPS will stop working. ,
- Fixed Quarantine does not work issue. ,
- Fixed the SSL VPN access issue that different domain users can access each other portal. ,
- Fixed that users cannot disable Scanning Compatibility Mode. ,
- Fixed unable to load valid certificate to the UTM. ,
- Fixed that Wireless profile is disabled itself randomly. ,
- Fixed sometimes VPN IPSec connection cannot be re-established. ,
- Fixed the issue that when Protocol binding on WAN2 is configured, port-forwards on WAN1 does not work. ,
- Fixed customer cannot modify the entry in the LAN groups table. ,
- Fixed the issue that IPSec VPN tunnel will not be re-establish after reboot. ,
- Fixed the issue that L2TP connection cannot be established. ,
- Fixed the issue that PPTP VPN connection is disconnected after short time. ,
- Fixed the issue that inbound FW rules stop working. ,
- Fixed the issue that Customer cannot establish VPN client-to-box tunnel. ,
- Fixed the issue that for Dual WAN Load balancing mode, RDP, SMTP and HTTP cannot be established. ,
- Fixed the blank page issue when customer navigates to VPN->SSL VPN -->Policies page, selects a particular group. ,
- Fixed that the IPSec VPN pre-shared key turns into VPN Issues Asterisks after upgrading to a new image. ,
- Fixed the duplicate Firewall services issue when customer add a service, it shows two duplicate services. ,
- Fixed unable to load valid certificate to the UTM due to spaces issue. ,
- Fixed not PCI compliant issue.
Using the Download Link below, download and extract the new firmware to a convenient place such as your desktop.
Download Links:
UTM 5 / 10 / 25: http://www.downloads.netgear.com/files/GDC/UTM10/UTM5_10_25-Firmware-V3.6.2-1.zip
UTM 50: http://www.downloads.netgear.com/files/GDC/UTM50/UTM50_Firmware-V3.6.2-1.zip
UTM 150: http://www.downloads.netgear.com/files/GDC/UTM150/UTM150_Firmware-V3.6.2-1.zip
UTM 9S/25S: http://www.downloads.netgear.com/files/GDC/UTM9S/UTM25S_9S-Firmware-V3.6.2-1.zip
