What are GSS108E and GSS116E?
They are ProSAFE 8-port and 16-port Gigabit Click Switches, offering the same software features as Plus Switches.
What is the key difference between NETGEAR Click Switch and NETGEAR Plus Switch?
Click switch offers the innovative 1-2-3-4 mounting system which gives you the flexibility to place the Click Switch in locations where other switches will not go. Whether it's directly on a wall, strapped to a pole, under the meeting table in a conference room or in a server closet, vertical or horizontal,the Click Switch's unique mounting system allow you to control exactly how your ports and cables are deployed.
What are the configurable features of Click Switch?
User can configure Port LED, Port Mirroring, VLAN, QoS, Rate Limit, IGMP Snooping and Broadcast Storm Filtering.
What’s the default IP address of GSS108E and GSS116E?
They support to get dynamic IP address from DHCP server by default. If a DHCP server is not installed in your network, the default IP address is 192.168.0.239
How can I configure GSS108E or GSS116E?
There is a configuration Plus Utility in the resource CD that comes with the device. You must install it on a window-based PC. Also, once you know the IP address through the Plus Utility, you can configure it via Web browser.
Do GSS108E and GSS116E support Flow Control?
Yes, GSS108E and GSS116E support Flow Control.
Do GSS108E and GSS116E support Port Auto Negotiation?
Yes, GSS108E and GSS116E support port auto negotiation for speed and duplex mode.
How do I know if there is a loop with the connection?
GSS108E and GSS116E support loop detection. When a loop is detected, both left and right LED on the affected port will blink at a constant speed with roughly 1 every second.
What is Auto DoS (Denial-of-Service) prevention?
DoS is a form of attack on computer network resources. The Auto DoS prevention feature would automatically block malicious packets such as source IP equals destination IP. GSS116E supports the Auto DoS but GSS108E doesn’t.
What is the purpose of Factory Defaults button?
This button is for user to reset all of the settings back to factory defaults.
What is the default password?
The default password is “password”.
What if I lost my password?
The password can be restored with the Factory defaults button. However, it would reset all configurations as well.
What is the function of 2 USB ports on GSS108E?
The two USB ports are only for charging devices like tablets and mobile phones. Maximum 10W can be provided with a single port and maximum 15W between the two.
