Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
When your licenses are installed and registered, you can view them on the Inventory screen.
»To view your licenses:
1. Open a web browser. In the browser’s address field, type the http:// followed by the IP address that you assigned to the wireless controller.
By default, the IP address is 192.168.0.250. If you have not yet assigned another IP address to the wireless controller, type http://192.168.0.250.
The wireless controller’s login screen displays.
2. Enter your user name and password.
If you have not yet personalized your user name and password, enter admin for the user name and password for the password, both in lowercase letters.
3. Click the Login button.
The wireless controller’s web management interface opens and displays the Summary screen.
4. Select Maintenance > Licensing.
5. Click the Inventory tab.
The Inventory screen displays:
The following table describes the fields of the screen:
 Setting  Description
 Summary section
 Total AP License  The number of access points that your licenses support.
 Nmode License Status  Availability of the 802.11n mode license. (This license is available by default, indicated by either Preinstalled or Available.)
 Used License Count  The number of access points that are used from the total number that your licenses support.
 Available License Count  The number of access points that are still available from the total number that your licenses support.
 Key Details section
 Key  The value of the key that unlocks the license.
 Key Type  The type of the key that determines the number of access points that are supported and the mode that is supported.
 Key Status  The status of the key (Registering key with server or Registered)
6. (Optional) Click the Refresh button.
Your license information is refreshed onscreen.
Last Updated:10/17/2025 | Article ID: 25679
This article applies to:
Recently Viewed Articles
    Our team is here to help!
    Phone
    Chat
    Email
