The Extended Storage screen displays information about an optionally attached external storage device such as a USB memory stick or external hard drive, and lets you mount and dismount the storage device. You can use an external storage device to store more floor heat maps and extended statistics history.
»To mount an external storage device and view information about the device:
- Select Maintenance > Extended Storage. The Extended Storage screen displays. As an example, the screen shows information about an attached USB memory stick.
.png)
- Attach the external storage device to the USB port on the front panel of the wireless controller.
Click Mount. The storage details become visible on the Extended Storage screen. Before you remove the external storage device from the USB port, click Unmount.
