Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
To configure IP, VLAN, and LAG settings:
  1. Open a web browser. In the browser's address field, type the http:// followed by the IP address that you assigned to the wireless controller.
    By default, the IP address is 192.168.0.250. If you have not yet assigned another IP address to the wireless controller, type http://192.168.0.250.
    The wireless controller's login screen displays.
  2. Enter your user name and password.
    If you have not yet personalized your user name and password, enter admin for the user name and password for the password, both in lowercase letters.
  3. Click the Login button.
    The wireless controller's web management interface opens and displays the Summary screen.
  4. Select Configuration > System > IP/VLAN.
    The IP Settings screen displays:
  5. Configure the settings as described in the following table:
     Setting Description
     IP Settings section
     IP Address  Enter the IP address of the wireless controller.
    The default IP address is 192.168.0.250. To change it, enter an available IP address from the address range used on your LAN.
     IP Subnet Mask  Enter the subnet mask value used on your LAN.
    The default value is 255.255.255.0.
     Default Gateway  Enter the IP address of the gateway for your LAN.
     Primary DNS Server  Enter the IP address of the primary Domain Name Server (DNS) that you want to use.
     Secondary DNS Server  Enter the IP address of the secondary DNS that you want to use.
     WINS Server  Enter the IP address of the Windows Internet Name Service (WINS) that you want to use.
     Management VLAN Settings section
     Management VLAN  Enter the management VLAN.
     Untagged VLAN  Select the Untagged VLAN check box if the configured VLAN is untagged.
     10G Port Settings section
     LAG  Select the LAG radio button to enable the wireless controller to automatically create a LAG in which both links are active.
    The LAG radio button and Active Standby radio button are mutually exclusive.
     Active Standby  Select the Active Standby radio button to enable the wireless controller to automatically create a LAG in which only one link is active and the other link functions as a standby link.
    The Active Standby radio button and LAG radio button are mutually exclusive.
  6. Click the Apply button.
Last Updated:10/17/2025 | Article ID: 25165
This article applies to:
Recently Viewed Articles
    Our team is here to help!
    Phone
    Chat
    Email
