Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
New Features:
  1. Extend logging time on ReadyNAS (The UTM can now store up to 2 years of logs on ReadyNAS).
  2. New ReadyNAS addon for ReadyNAS OS 6.x (x86 platform)
  3. Add the capability to download and read UTM release notes directly from the UTM GUI
  4. Removed the extra step previously required to register the IPS & application control license
  5. Removed the license backdating in the event that a license renewed after it had already expired.
  6. Added the ability to reset the admin password and also the ability to query the LAN settings by CLI command
  7. Change HTTPS remote management settings from enabled by default to disabled by default.
  8. All the registered maintenance license keys (including the expired maintenance license keys) will be extended to the end of 2016. The new maintenance license registration will be extended to the end of 2016. Customers will not be able to stack subscriptions beyond 12/31/2016. Any subscription that extends beyond that date will be adjusted to finish on that date.
Note: ReadyNAS add-on 2.x & firmware compatibility – The ReadyNAS add-on 2.x only works with firmware version V3.6.1-18 and above and vice versa. The previous RN add-on release is 1.x.
Bug Fixes:
  1. Fixed bug where Scanning Compatibility Mode doesn't turn off automatically
  2. Fixed the bug where the UTM150 NAT loopback did not work
  3. Fixed the bug where Internet access stopped while the UTM9S was copying files across VLANs with QoS enabled
  4. Fixed the issue where the UTM150 would lose its Secondary WAN address after reboot
  5. Fixed issue where no traffic would pass through the IPsec VPN tunnel when AES-256 and SHA2-256 are used at the same time.
  6. Fixed issue on the UTM150 where the web GUI will be unavailable intermittently
  7. Fixed issue on the UTM9S where the password for a newly created user could not be changed.
  8. Fixed issue where a statically configured IPOA WAN IP address would change to the UTM’s LAN IP address upon reboot
  9. Fixed issue where the user could not change any settings in the Attack Check menu.
  10. Fixed issue where QoS cannot select a VLAN on the DSL interface on UTM9S/UTM25S
  11. Fixed the issue on the UTM25S where the Ike policy would lose the local IP address after WAN3 (slot-1) restarts
  12. Fixed issue on the UTM50 where in certain cases the Firewall rules could not be changed
  13. Fixed issue on UTM150 where after loading a custom configuration file, the device loses its IKE and VPN policies
  14. Fixed issue where a second VPN policy would not be bound to an IKE policy that has already been bound to another VPN policy.
  15. Fixed issue where outbound email would not send with a Google Mail account when IMAPS scanning is enabled on the UTM
  16. Fixed issue where the Google Safe Search option was not properly removed from exception list on the GUI
  17. Removed the Google Safe Search function due to a change in Google’s infrastructure
  18. Fixed issue on UTM10 when bandwidth profile is enabled, a LAN PC cannot access the server on the WAN side
  19. Fixed issue with SIP where certain VoIP phone could call in and out, but no voice data would come through
  20. Fixed DNS Lookup not working in certain cases on the UTM50
  21. Fixed issue where the UTM9S can't establish an Internet connection after Firmware upgrade
  22. Fixed issue where the Internet would be unusable if both WANs are using PPPoE
  23. Fixed issue where the Traffic Meter page shows error "Unable to process request. Unrecognized command." Under certain conditions
Known Issues:
  1. MTU on WAN interface shouldn't be allowed
  2. A user with Guest privileges is able to establish/drop an IPsec VPN tunnel.
  3. A user with Guest privileges is able to perform operations on the WAN status page
  4. The Guest user is able to change the password after login from the default portal link.
  5. A user with Guest privileges is not automatically logged out after the admin changes the guest password
  6. "Deny Login from WAN interface" option is unchecked by default for custom guest user in login policies page.
  7. UTM is not broadcasting its connected VLAN interface routes
  8. Able to add two routes for the same destination with two different gateways in Load Balancing
To Install:
Firmware upgrade from update server:
  • Installed firmware versions older than 1.3.7:
    If your firmware is older than 1.3.7 (<1.3.7) it cannot be updated directly to firmware newer than 1.3.7. Only firmware images older than 1.3.7 will be displayed when you query the update server (Application=>System Update=>Firmware). To upgrade to firmware newer than 1.3.7 you must first upgrade your system to 1.3.7. You can then perform the firmware update query again to display the newer firmware images (Application=>System Update=>Firmware).
  • Installed firmware versions 1.3.7 and above:
    If your firmware is version 1.3.7 or above, when you query the update server all firmware versions will be displayed.
Using the Download Link below, download and extract the new firmware to a convenient place such as your desktop.
Download Links:
UTM 5 / 10 / 15: http://www.downloads.netgear.com/files/GDC/UTM10/UTM5_10_25_Firmware_V3.6.1-20.zip
UTM 50: http://www.downloads.netgear.com/files/GDC/UTM50/UTM50_Firmware_V3.6.1-20.zip
UTM 150: http://www.downloads.netgear.com/files/GDC/UTM150/UTM150_Firmware_V3.6.1-20.zip
This product includes software code developed by third parties, including software code subject to the GNU General Public License ("GPL") or GNU Lesser General Public License ("LGPL"). As applicable, the terms of the GPL and LGPL, and information on obtaining access to the GPL Code and LGPL Code used in this product, are available to you at NETGEAR's Open Source Code Web page
Last Updated:10/17/2025 | Article ID: 24892
This article applies to:
Recently Viewed Articles
    Our team is here to help!
    Phone
    Chat
    Email
