Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
The GS516TP, GS728TP, GS728TPP, and GS752TP smart switches differ in hardware from other smart switches.
On these models, jumbo frames function differently than on other smart switch models:
  • You can enable jumbo frames globally only, not per port.
  • By default, jumbo frames are disabled and the switch supports a packet size of up to 2,048 bytes. Other switch models support a packet size of up to 1,518 bytes when Jumbo frames are disabled.
  • When you enable jumbo frames, you cannot configure the maximum frame size, which is set at 9,216 bytes.
  • When you enable jumbo frames, you must reboot the switch for Jumbo frames to be activated.
For information about enabling jumbo frames on smart switch models GS516TP, GS728TP, GS728TPP, and GS752TP, see the “How do I enable jumbo frames on smart switch models GS516TP, GS728TP, GS728TPP, and GS752TP
Last Updated:07/07/2025 | Article ID: 24759
Our team is here to help!
Phone
Chat
Email
