When the router is turned on, the Power LED lights amber for about 20 seconds and then lights white. If the LED does not light white, the router has a problem.
If the Power LED is still amber one minute after you turn on power to the router, do the following:
- Turn off the power and then turn it back on to see if the router recovers.
- Press and hold the Reset button to return the router to its factory settings.
If the error persists, you might have a hardware problem. Contact technical support at www.netgear.com/support.
