Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
The router can act as a wireless base station or a wireless repeater in a wireless distribution system (WDS). A WDS expands a wireless network through multiple access points. A wireless base station connects to the Internet, can have wired and wireless clients, and sends its wireless signal to an access point that functions as a wireless repeater. A wireless repeater can also have wired and wireless clients, but connects to the Internet through the wireless base station. The following figure shows a wireless repeating scenario.
Note: Product appearance varies by model.
Note:
To use the wireless repeating function, your router cannot have security enabled and cannot use the auto channel feature.
You must set up a wireless base station and a wireless repeater:
  • Wireless base station. The router acts as the parent access point that bridges traffic to and from the child repeater access point. The base station also handles wireless and wired local computers. To configure this mode, you must know the MAC addresses of the child repeater access point. Often, the MAC address is on the product label.
  • Wireless repeater. The router sends all traffic from its local wireless or wired computers to a remote access point. To configure this mode, you must know the MAC address of the remote parent access point.
The router is always in dual-band concurrent mode, unless you turn off one radio. If you enable the wireless repeater in either radio band, the wireless base station or wireless repeater cannot be enabled in the other radio band. However, if you enable the wireless base station in either radio band and use the other radio band as a wireless router or wireless base station, dual-band concurrent mode is not affected.
Before you set up a wireless network with WDS, both access points must meet the following conditions:
  • Use the same SSID, wireless channel, and encryption mode.
  • Be on the same LAN IP subnet. That is, all of the access point LAN IP addresses are in the same network.
  • All LAN devices (wired and wireless computers) are configured to operate in the same LAN network address range as the access points.
For more information on setting up a wireless distribution system on your router, see the following support articles:
Last Updated:07/07/2025 | Article ID: 24106
This article applies to:
Recently Viewed Articles
    Our team is here to help!
    Phone
    Chat
    Email
