Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
To view the properties of a volume:
1. Select System > Storage.
The Storage screen displays.
2. To the left of the graphical enclosure, click the volume that you want to explore.
3. Click the gear icon.
A pop-up menu displays (see the figure in Step 4).
4. Select Properties.
The properties of the volume display at the right side of the screen in the Summary section (see the figure in Step 7).
5. (Optional) Click I/O Stats.
I/O statistics display.
6. (Optional) Click Disks.
7. Status and health information about the disks that are members of the volume displays.
Note: You can also use a shortcut to display the properties of a volume. Click the screen Expand button (Image) on the top right of the screen to display the properties (see the red oval in the previous figure). Click the same button (which now shows a reversed arrow Image) again to hide the properties (see the red oval in the previous figure).
The following table explains the properties:
Item
Description
Summary
RAID
The configured RAID level.
Data
The storage space that is consumed by data in MB, GB, or TB.
Snapshots
The number of snapshots that have been taken.
Reserved
The storage space that is reserved in MB, GB, or TB.
Free
The storage space that is available in MB, GB, or TB and in a percentage.
Health
The health of the volume. The options are:
  • Online. The volume is healthy.
  • Degraded. The volume is degraded.
Guid
The globally unique identifier (GUID) for the volume. The GUID allows you to use the volume GUID path, for example, "\?Volume{17303906860048588325}".
I/O Stats
Operations
The number of read operations and the number of write operations on the volume.
Bandwidth
The volume bandwidth throughput in bytes.
Disks
For information about health and status information that is displayed for each disk that is a member of the volume, see the How do I view disk status and health information for an individual disk on my ReadyDATA storage system?
Last Updated:07/07/2025 | Article ID: 23534
This article applies to:
Recently Viewed Articles
    Our team is here to help!
    Phone
    Chat
    Email
