Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
The ReadyDATA provides status graphics for volume throughput, network throughput, volume utilization, and system temperatures.
To display and configure the system status graphics:
Click System > Overview.
The Dashboard home screen displays. The following status monitoring graphics are located below the Hardware section (if a graphic does not display, click the associated heading on the left of the screen):
Volume.
The Volume throughput graphic shows either the number of read and write operations per second or the bandwidth consumed per second:
- Operations. The range is flexible and depends on your selections from the drop-down lists above the graphic. For example, the range can be from 0 to 200 operations. The upper part of the graphic indicates the number of read operations (indicated by positive numbers); the lower part of the graphic indicates the number of write operations (indicated by negative numbers).
- Bandwidth. The range is flexible and depends on your selections from the drop-down lists above the graphic. For example, the range can be from 0 to 4 Mbps. The upper part of the graphic indicates the bandwidth consumed for read operations (indicated by positive numbers); the lower part of the graphic indicates the bandwidth consumed for write operations (indicated by negative numbers).
From the drop-down lists above the graphic, you can adjust the following settings:
- Volume. Select all volumes or individual volumes.
- Operations. Select the number of operations per second or the bandwidth consumed per second.
- Period. Select the period over which the operations or bandwidth is measured. You can select from five minutes to one year.
- Update. Select how often the information in the graphic is updated. You can select from 5 to 50.
Network.
The Network throughput table shows the network usage for Tx and Rx traffic in bytes per second. The range is flexible and depends on your selections from the drop-down lists above the graphic. For example, the range can be 0 to 60 bytes or from 0 to 40 KB. The upper part of the graphic indicates the Rx traffic; the lower part of the graphic indicates the Tx traffic.
- Network. Select all network interfaces, individual interfaces, individual VNICs, or individual aggregation links.
- Protocol. Select all protocols or individual protocols (SMB, NFS, AFP, HTTP, SSH, iSCSI, or SNMP).
- Period. Select the period over which the network usage is measured. You can select from five minutes to one year.
- Update. Select how often the information in the table is updated. You can select from 5 to 50 seconds. seconds.
Utilization.
The Volume utilization graphic shows the percentage that an individual volume or all volumes are used. The range is from 0 to 100 percent.
- Period. Select the period over which the utilization is measured. You can select from five minutes to one year.
Temperature.
The Temperature graphic shows the system temperatures in degrees Celsius. The range is flexible and depends on your selections from the drop-down lists above the graphic and the temperatures that are measured. For example, the range can be from 0 to 50 degrees Celsius.
- Temperature. Select all temperatures, the system (SYS) temperature, the CPU temperature, or the auxiliary (AUX) temperature.
- Period. Select the period over which the temperatures are measured. You can select from five minutes to one year.
Last Updated:07/07/2025 | Article ID: 23499
This article applies to:
Recently Viewed Articles
    Our team is here to help!
    Phone
    Chat
    Email
