Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
To make sure that the ReadyDATA correctly displays file names, configure the system to use the appropriate character set. For example, selecting Japanese allows the ReadyDATA to support files with Japanese names in Windows Explorer.
To configure language settings:
1. On the navigation bar, at the right, click Profile.
The Profile menu displays:
2. In the Language section, specify a language by selecting a check box, or select the Auto check box, which enables the ReadyDATA to set the language automatically to the one that is used by the browser.
After you change the language, Dashboard restarts.
        Note: NETGEAR recommends selecting a language based on the region in which you use the ReadyDATA.
Last Updated:07/07/2025 | Article ID: 23466
This article applies to:
Recently Viewed Articles
    Our team is here to help!
    Phone
    Chat
    Email
