The volumes on your ReadyNAS can be divided into shares and logical unit numbers (LUNs), both of which are logical entities on one or more disks. Shares and LUNs enable you to organize data in a volume by type, group, user, department, and so on. A single volume can contain multiple shares and LUNs.
LUNs are SAN (storage area network) data sets that allow data transfer and storage over iSCSI and Fibre Channel devices. The ReadyNAS supports iSCSI devices only. Each ReadyNAS system supports up to 256 LUNs. The Admin Page displays LUNs in the following way:
Thin LUN
Thick LUN
Each LUN is configured independently of other LUNs that reside on the same volume. You can configure settings such as compression, protection, provisioning, LUN size, and access rights. You can also specify whether and how often a snapshot is created. These settings are explained in the following sections.
Thin vs. Thick Provisioning
You can specify the size of a LUN in two ways:
Thin. A thin LUN lets you overallocate its size. That is, you can assign a LUN size that is larger than the size of the volume. Even though you specify the size of a thin LUN when you create it, storage space is assigned on demand instead of up front. This method greatly improves the utilization rate of the LUN because storage space is assigned only as data is written to the LUN. However, the size of the LUN is reported as the total storage space that you specify when you create the LUN.
You can expand a volume as needed (if necessary, adding disks in the process) without expanding the size of the LUN and therefore, without disconnecting users. Make sure that you watch the volume capacity of the volume on which the overallocated LUN resides so you do not run out of storage space unexpectedly.
Note: NETGEAR recommends that you do not use an overallocated LUN for storage of critical data. Instead, use a thick LUN.
Thick. All storage space that you specify when you create a thick LUN is allocated up front and the storage space is reserved on the volume. Snapshots, other LUNs, and shared folders on the volume cannot consume storage space that is reserved. The size of the LUN is reported as the total storage space that you specify when you create the LUN. You cannot assign more storage space than the available non-reserved storage space on the volume.
Default LUN Settings
The following table explains the default settings of a LUN. You can change these settings when you create or change the LUN.
Item |
Default State |
Compression |
Disabled |
Continuous Protection |
Enabled |
Interval |
Daily |
Provision |
Thick |
Access |
Denied until you set permissions |
For information on creating and managing LUNs, see the following support articles:
- How do I create a LUN on my ReadyNAS OS 6 storage system?
- How do I view and change the properties of a LUN on my ReadyNAS OS 6 storage system?
- How do I expand the size of a LUN on my ReadyNAS OS 6 storage system?
- How do I delete a LUN on my ReadyNAS OS 6 storage system?
