To display and manage the system logs:
1. Select System > Logs and Alerts.
2. (Optional) To view additional messages, use the navigation box in the lower left corner of the screen.
3. Do any of the following:
Download the logs. Click the Download Logs button to download a zipped file with all log files to your browser's default download location. The default name of the zipped file is System_log-<host name>.zip, in which <host name> is the host name of the ReadyNAS. For more information on configuring the host name, please see the How do I change the host name on my ReadyNAS OS 6 storage system?
Clear the logs. Click the Clear Logs button. The log entries onscreen are cleared but the log files remain intact.
Configure the logs. Under Records, select which message levels and categories are logged. These selections affect the system logs, alerts, SNMP traps, and onscreen messages.
Message levels. By default, the Errors, Warnings, and Info check boxes are selected, causing errors, warnings, and informational messages to be logged. You can clear any check boxes.
Message categories. By default, messages for all categories are logged. From the drop-down list, you can select to log individual categories only: System, Disk, Volume, Share, Account, or Miscellaneous.
