Configure Switch GSM7328S_1
- Enable IP routing on the switch.
- Select Routing > IP > Basic > IP Configuration.
A screen similar to the following displays.
- For Routing Mode, select the Enable radio button.
- Click Apply.
- Enable IPv6 forwarding and unicast routing on the switch.
- Select Routing > IPv6 > Basic> Global Configuration.
- For IPv6 Unicast Routing, select the Enable radio button.
- For IPv6 Forwarding, select the Enable radio button.
- Click Apply.
- Create a routing interface and assign an IP address to it.
- Select Routing > IP > Advanced > IP Interface Configuration.
- Under IP Interface Configuration, scroll down and select the Port 1/0/1 check box.
Now 1/0/1 appears in the Interface field at the top.- In the IP Address field, enter 192.168.1.1.
- In the Subnet Mask field, enter 255.255.255.0.
- In the Routing Mode field, select Enable.
- Click Apply.
- Create a 6-in-4 tunnel interface.
- Select Routing > IPv6 > Advanced > Tunnel Configuration.
- In the Tunnel Id list, select 0.
- In the Mode field, select 6-in-4-configured.
- In the Source Address field, enter 192.168.1.1.
- In the Destination Address field, enter 192.168.1.2.
- Click Apply.
- Assign an IPv6 address to the tunnel.
- Select Routing > IPv6 > Advanced > Prefix Configuration.
- In the Interface list, select 0/7/1.
- In the IPv6 Prefix field, enter 2000::1.
- In the Length field, enter 64.
- In the EUI64 field, select Disable.
- Click Add.
Configure Switch GSM7328S_2
- Click Apply.
- Select Routing > IPv6 > Basic > Global Configuration.
- Click Apply.
- Under IP Interface Configuration, scroll down and select the Port 1/0/13 check box.
Now 1/0/1 appears in the Port field at the top.- In the IP Address field, enter 192.168.1.2.
- Click Apply.
- In the Mode list, select 6-in-4-configured.
- In the Source Address field, enter 192.168.1.2.
- In the Destination Address field, enter 192.168.1.1.
- Click Apply.
- In the IPv6 Prefix field, enter 2000::2.
- Click Add.
For more information, see the following support articles:
- What is a tunnel and how does it work with my managed switch?
- How do I create a tunnel using CLI commands on my managed switch?
This article applies to the following managed switches and their respective firmware:
- M5300 - firmware version 10.0.0.x
- M5300-28G (GSM7228S)
- M5300-5G (GSM7252S)
- M5300-28G3 (GSM7328Sv2h2)
- M5300-52G3 (GSM7352Sv2h2)
- M5300-28G_POE+ (GSM7228PSv1h2)
- M5300-52G-POE+ (GSM7252PSv1h2)
- M5300-28GF3 (GSM7328FSv2)
- XSM7224S - firmware version 9.0.1.x (license required to support the feature described in this article)
