Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
  1. Configure the sFlow receiver IP address.
    1. Select Monitoring > sFlow > Advanced > sFlow Receiver Configuration.
    2. Select the 1 check box.
    3. In the Receiver Owner field, enter NetMonitor.
    4. In the Receiver Timeout field, enter 31536000.
    5. In the Receiver Address field, enter 192.168.10.2.
      A screen similar to the following displays.
    6. Click Apply.
  2. Configure the sampling ports sFlow receiver index, sampling rate, and sampling maximum header size.
    1. Select Monitoring > sFlow > Advanced > sFlow Interface Configuration.
    2. Select the Interface 1/0/1 check box.
    3. In the Sampling Rate field, enter 1024.
    4. In the Maximum Header Size field, enter 64.
    5. Click Apply.
For more information, see the following support articles:
This article applies to the following managed switches and their respective firmware:
  • M5300 - firmware version 10.0.0.x
    • M5300-28G (GSM7228S)
    • M5300-5G (GSM7252S)
    • M5300-28G3 (GSM7328Sv2h2)
    • M5300-52G3 (GSM7352Sv2h2)
    • M5300-28G_POE+ (GSM7228PSv1h2)
    • M5300-52G-POE+ (GSM7252PSv1h2)
    • M5300-28GF3 (GSM7328FSv2)
  • M4100 - firmware version 10.0.1.x
    • M4100-26G (GSM7224v2h2)
    • M4100-50G (GSM7248v2h2)
    • M4100-26G-POE (GSM7226Pv1h1)
    • M4100-50G-POE+ (GSM7248Pv1h1)
    • M4100-26G-POE (FSM7226Pv1h1)
    • M4100-50-POE (FSM7250Pv1h1)
    • M4100-D12G (GSM5212v1h1)
    • M4100-D10-POE (FSM5210Pv1h1)
  • M7100 - firmware version 10.0.1.x
    • M7100-24X (XSM7224)
  • XSM7224S - firmware version 9.0.1.x
Last Updated:07/07/2025 | Article ID: 21920
Our team is here to help!
Phone
Chat
Email
