- Configure the syslog.
- From the main menu, select Monitoring > Logs > Sys Log Configuration.
- In the Syslog Configuration, next to the Admin Status, select the Enable radio button.
- Click Apply.
- Configure the command log.
- Select Monitoring > Logs > Command Log.
- Under Command Log, for Admin Status, select the Disable radio button.
- Click Apply.
- Configure the console log.
- Select Monitoring > Logs > Console Log.
- Under Console Log Configuration, for Admin Status, select the Disable radio button.
- Click Apply.
- Configure the buffer logs.
- Select Monitoring > Logs > Buffer Logs.
A screen similar to the following displays.
- Under Buffer Logs, for Admin Status, select the Enable radio button.
- Click Apply.
For more information, see the following support articles:
- What is the Syslog feature and how does it work with my managed switch?
- How do I show logging using CLI commands on my managed switch?
This article applies to the following managed switches and their respective firmware:
- M5300 - firmware version 10.0.0.x
- M5300-28G (GSM7228S)
- M5300-5G (GSM7252S)
- M5300-28G3 (GSM7328Sv2h2)
- M5300-52G3 (GSM7352Sv2h2)
- M5300-28G_POE+ (GSM7228PSv1h2)
- M5300-52G-POE+ (GSM7252PSv1h2)
- M5300-28GF3 (GSM7328FSv2)
- M4100 - firmware version 10.0.1.x
- M4100-26G (GSM7224v2h2)
- M4100-50G (GSM7248v2h2)
- M4100-26G-POE (GSM7226Pv1h1)
- M4100-50G-POE+ (GSM7248Pv1h1)
- M4100-26G-POE (FSM7226Pv1h1)
- M4100-50-POE (FSM7250Pv1h1)
- M4100-D12G (GSM5212v1h1)
- M4100-D10-POE (FSM5210Pv1h1)
- M7100 - firmware version 10.0.1.x
- M7100-24X (XSM7224)
- XSM7224S - firmware version 9.0.1.x
