Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
Configuration scripting:
  • Allows you to generate text-formatted files.
  • Provides scripts that can be uploaded and downloaded to the system.
  • Provides flexibility to create command configuration scripts.
  • Can be applied to several switches.
  • Can save up to 10 scripts or 500 K of memory.
  • Provides script format of one CLI command per line.
Here are some considerations:
  • The total number of scripts stored is limited by the NVRAM/FLASH size.
  • Application of scripts is partial if a script fails. For example, if the script executes 5 of 10 commands and the script fails, the script stops at 5.
  • Scripts cannot be modified or deleted while being applied.
  • Validation of scripts checks for syntax errors only. It does not validate that the script will run successfully.
For more information, see the following support articles:
This article applies to the following managed switches and their respective firmware:
  • M5300 - firmware version 10.0.0.x
    • M5300-28G (GSM7228S)
    • M5300-5G (GSM7252S)
    • M5300-28G3 (GSM7328Sv2h2)
    • M5300-52G3 (GSM7352Sv2h2)
    • M5300-28G_POE+ (GSM7228PSv1h2)
    • M5300-52G-POE+ (GSM7252PSv1h2)
    • M5300-28GF3 (GSM7328FSv2)
  • M4100 - firmware version 10.0.1.x
    • M4100-26G (GSM7224v2h2)
    • M4100-50G (GSM7248v2h2)
    • M4100-26G-POE (GSM7226Pv1h1)
    • M4100-50G-POE+ (GSM7248Pv1h1)
    • M4100-26G-POE (FSM7226Pv1h1)
    • M4100-50-POE (FSM7250Pv1h1)
    • M4100-D12G (GSM5212v1h1)
    • M4100-D10-POE (FSM5210Pv1h1)
  • M7100 - firmware version 10.0.1.x
    • M7100-24X (XSM7224)
  • XSM7224S - firmware version 9.0.1.x
Last Updated:07/07/2025 | Article ID: 21840
Our team is here to help!
Phone
Chat
Email
