Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
sThis example redirects the HTTP traffic stream received in port 1/0/1 to port 1/0/19.
  1. Create an IP access control list with the name redirectHTTP.
    1. Select Security > ACL > Advanced > IP ACL.
      A screen similar to the following displays.
    2. In the IP ACL field, enter redirectHTTP.
    3. Click Add to create the IP ACL redirectHTTP.
  2. Create a rule to redirect HTTP traffic.
    1. Select Security > ACL > Advanced > IP Extended Rules.
    2. Click Add, and the Extended ACL Rule Configuration screen displays.
    3. In the Rule ID field, enter 1.
    4. For Action, select the Permit radio button.
    5. In the Redirect Interface list, select 1/0/19.
    6. In the Dst L4 Port list, select http.
    7. Click Apply.
      The Extended ACL Rules screen displays, as described in the next step in this procedure.
  3. Create a rule to match every other traffic.
    3. In the Rule ID field, enter 2.
    5. In the Match Every field, select True.
    6. Click Apply.
  4. Bind the ACL with interface 1/0/1.
    1. Select Security > ACL > Advanced > IP Binding Configuration.
    2. In the Sequence Number field, enter 1.
    3. In the Port Selection Table, click Unit 1 to display all the ports.
    4. Select the check box below Port 1.
    5. Click Apply.
      At the end of this configuration a screen similar to the following displays.
For more information, see the following support articles:
This article applies to the following managed switches and their respective firmware:
  • M5300 - firmware version 10.0.0.x
    • M5300-28G (GSM7228S)
    • M5300-5G (GSM7252S)
    • M5300-28G3 (GSM7328Sv2h2)
    • M5300-52G3 (GSM7352Sv2h2)
    • M5300-28G_POE+ (GSM7228PSv1h2)
    • M5300-52G-POE+ (GSM7252PSv1h2)
    • M5300-28GF3 (GSM7328FSv2)
  • M4100 - firmware version 10.0.1.x
    • M4100-26G (GSM7224v2h2)
    • M4100-50G (GSM7248v2h2)
    • M4100-26G-POE (GSM7226Pv1h1)
    • M4100-50G-POE+ (GSM7248Pv1h1)
    • M4100-26G-POE (FSM7226Pv1h1)
    • M4100-50-POE (FSM7250Pv1h1)
    • M4100-D12G (GSM5212v1h1)
    • M4100-D10-POE (FSM5210Pv1h1)
  • M7100 - firmware version 10.0.1.x
    • M7100-24X (XSM7224)
  • XSM7224S - firmware version 9.0.1.x
Last Updated:07/07/2025 | Article ID: 21728
Our team is here to help!
Phone
Chat
Email
