Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
This example adds support for OSPF to the configuration below.
The diagram in this article shows a Layer 3 switch configured for port routing. It connects two VLANs, with two ports participating in one VLAN, and one port in the other.
  1. Configure the M5300 Managed Switch as an inter-area router.
    (Netgear Switch) #vlan data
    (Netgear Switch) (Vlan)#vlan 10
    (Netgear Switch) (Vlan)#vlan 20
    (Netgear Switch) (Vlan)#vlan routing 10
    (Netgear Switch) (Vlan)#vlan routing 20
    (Netgear Switch) (Vlan)#exit
    (Netgear Switch) #conf
    (Netgear Switch) (Config)#ip routing
    (Netgear Switch) (Config)#vlan port tagging all 10
    (Netgear Switch) (Config)#vlan port tagging all 20
    (Netgear Switch) (Config)#interface 1/0/2
    (Netgear Switch) (Interface 1/0/2)#vlan participation include 10
    (Netgear Switch) (Interface 1/0/2)#vlan pvid 10
    (Netgear Switch) (Interface 1/0/2)#exit
    (Netgear Switch) (Config)#interface 1/0/3
    (Netgear Switch) (Interface 1/0/3)#vlan participation include 20
    (Netgear Switch) (Interface 1/0/3)#vlan pvid 20
    (Netgear Switch) (Interface 1/0/3)#exit
    (Netgear Switch) (Config)#interface vlan 10
    (Netgear Switch) (Interface vlan 10)#ip address 192.150.3.1 255.255.255.0
    (Netgear Switch) (Interface vlan 10)#exit
    (Netgear Switch) (Config)#interface vlan 20
    (Netgear Switch) (Interface vlan 20)#ip address 192.150.4.1 255.255.255.0
    (Netgear Switch) (Interface vlan 20)#exit
  2.  Specify the router ID and enable OSPF for the switch.
    (Netgear Switch) (Config)#router ospf
    (Netgear Switch) (Config router)#router-id 192.150.9.9
    (Netgear Switch) (Config router)#enable
    (Netgear Switch) (Config router)#exit
  3. Enable OSPF for the VLAN and physical router ports.
    (Netgear Switch) (Interface vlan 10)#ip ospf areaid 0.0.0.2
    (Netgear Switch) (Interface vlan 20)#ip ospf areaid 0.0.0.3
  4. Set the OSPF priority and cost for the VLAN and physical router ports.
    (Netgear Switch) (Interface vlan 10)#ip ospf priority 128
    (Netgear Switch) (Interface vlan 10)#ip ospf cost 32
    (Netgear Switch) (Interface vlan 20)#ip ospf priority 255
    (Netgear Switch) (Interface vlan 20)#ip ospf cost 64
    (Netgear Switch) (Config)#exit
For more information, see the following support articles:
This article applies to the following managed switches and their respective firmware:
  • M5300 - firmware version 10.0.0.x
    • M5300-28G (GSM7228S)
    • M5300-5G (GSM7252S)
    • M5300-28G3 (GSM7328Sv2h2)
    • M5300-52G3 (GSM7352Sv2h2)
    • M5300-28G_POE+ (GSM7228PSv1h2)
    • M5300-52G-POE+ (GSM7252PSv1h2)
    • M5300-28GF3 (GSM7328FSv2)
  • XSM7224S - firmware version 9.0.1.x (license required to support the feature described in this article)
Last Updated:07/07/2025 | Article ID: 21692
Our team is here to help!
Phone
Chat
Email
