Routing Information Protocol (RIP) is a protocol that routers can use to exchange network topology information. It is characterized as an interior gateway protocol, and is typically used in small to medium-sized networks. A router running RIP sends the contents of its routing table to each of its adjacent routers every 30 seconds. When a route is removed from the routing table, it is flagged as unusable by the receiving routers after 180 seconds, and removed from their tables after an additional 120 seconds.
Two versions of RIP exists and a NETGEAR fully managed switch supports both:
- RIPv1 defined in RFC 1058:
- Routes are specified by IP destination network and hop count.
- The routing table is broadcast to all stations on the attached network.
- RIPv2 defined in RFC 1723:
- Route specification also includes subnet mask and gateway.
- The routing table is sent to a multicast address, reducing network traffic.
- Authentication is used for security.
You can configure a port to do the following:
- Receive packets in either or both formats.
- Send packets formatted for RIPv1 or RIPv2, or send RIPv2 packets to the RIPv1 broadcast address.
- Prevent any RIP packets from being received.
- Prevent any RIP packets from being sent.
The following figure shows a network with RIP on ports 1/0/2 and 1/0/3.
