Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
  1. Select Routing > Routing Table > Basic > Route Configuration to display the Route Configuration screen.
  2. In the Route Type list, select Static.
  3. Fill in the Network Address field. Note that this field should have a network IP address, not a host IP address.
    Do not enter something like 10,100.100.1. The last number should always be zero.
  4. In the Subnet Mask field, enter a value that matches the subnet range that you want to use.
  5. The Preference field is optional.
    A value of 1 is entered by default if you do not enter a number.
  6. Click Add on the bottom of the screen.
    The screen is updated with the static route shown in the routing table.
  7. To remove a route entry, either static or default, select the check box to the left of the entry, and click Delete on the bottom of the screen.
Last Updated:07/07/2025 | Article ID: 21654
Our team is here to help!
Phone
Chat
Email
