Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
Use the following Web interface to enable routing for ports on the switch. The default link-level encapsulation format is Ethernet. Configure the IP addresses and subnet masks for the ports. Network-directed broadcast frames will be dropped. The maximum transmission unit (MTU) size is 1500 bytes.
  1. Assign IP address 192.150.2.1/24 to interface 1/0/2.
    1. Select Routing > IP > Advanced > IP Interface Configuration.
      A screen similar to the following displays.
    2. Scroll down and select the interface 1/0/2 check box.
      Now 1/0/2 appears in the Interface field at the top.
    3. Under the IP Interface Configuration, enter the following information:
      • In the IP Address field, enter 192.150.2.1.
      • In the Subnet Mask field, enter 255.255.255.0.
      • In the Routing Mode field, select Enable.
    4. Click Apply to save the settings.
  2. Assign IP address 192.150.3.1/24 to interface 1/0/3.
    1. Select Routing > IP> Advanced > IP Interface Configuration.
    2. Scroll down and select the interface 1/0/3 check box.
      Now 1/0/3 appears in the Interface field at the top.
    3. Enter the following information:
      • In the IP Address field, enter 192.150.3.1.
  3. Assign IP address 192.150.5.1/24 to interface 1/0/5.
    2. Scroll down and select the interface 1/0/5 check box.
      Now 1/0/5 appears in the Interface field at the top.
      • In the IP Address field, enter 192.150.5.1.
For more information see the  support article.
This article applies to the following managed switches and their respective firmware:
  • M5300 - firmware version 10.0.0.x
    • M5300-28G (GSM7228S)
    • M5300-5G (GSM7252S)
    • M5300-28G3 (GSM7328Sv2h2)
    • M5300-52G3 (GSM7352Sv2h2)
    • M5300-28G_POE+ (GSM7228PSv1h2)
    • M5300-52G-POE+ (GSM7252PSv1h2)
    • M5300-28GF3 (GSM7328FSv2)
  • M4100 - firmware version 10.0.1.x
    • M4100-26G (GSM7224v2h2)
    • M4100-50G (GSM7248v2h2)
    • M4100-26G-POE (GSM7226Pv1h1)
    • M4100-50G-POE+ (GSM7248Pv1h1)
    • M4100-26G-POE (FSM7226Pv1h1)
    • M4100-50-POE (FSM7250Pv1h1)
    • M4100-D12G (GSM5212v1h1)
    • M4100-D10-POE (FSM5210Pv1h1)
  • M7100 - firmware version 10.0.1.x
    • M7100-24X (XSM7224)
  • XSM7224S - firmware version 9.0.1.x
Last Updated:07/07/2025 | Article ID: 21647
Our team is here to help!
Phone
Chat
Email
