Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
This sequence shows how to assign ports to VLAN2, and to specify that frames will always be transmitted tagged from all member ports and that untagged frames will be rejected on receipt.
  1. Assign ports to VLAN2.
    1. Select Switching > VLAN > Advanced > VLAN Membership.
      A screen similar to the following displays.
    2. In the VLAN ID list, select 2.
    3. Click Unit 1. The ports display.
    4. Click the gray boxes under ports 1 and 2 until T displays.
      The T specifies that the egress packet is tagged for the ports.
    5. Click Apply to save the settings.
  2. Specify that only tagged frames will be accepted on ports 1/0/1 and 1/0/2.
    1. Select Switching > VLAN > Advanced > Port PVID Configuration.
    2. Under PVID Configuration, scroll down and select the check box for Interface 1/0/1.
      Then scroll down and select the Interface 1/0/2 check box.
    3. Enter the following information:
      • In the Acceptable Frame Type polyhedron list, select VLAN Only.
      • In the PVID (1 to 4093) field, enter 2.
    4. Click Apply to save the settings.
For more information, see the following support articles:
This article applies to the following managed switches and their respective firmware:
  • M5300 - firmware version 10.0.0.x
    • M5300-28G (GSM7228S)
    • M5300-5G (GSM7252S)
    • M5300-28G3 (GSM7328Sv2h2)
    • M5300-52G3 (GSM7352Sv2h2)
    • M5300-28G_POE+ (GSM7228PSv1h2)
    • M5300-52G-POE+ (GSM7252PSv1h2)
    • M5300-28GF3 (GSM7328FSv2)
  • M4100 - firmware version 10.0.1.x
    • M4100-26G (GSM7224v2h2)
    • M4100-50G (GSM7248v2h2)
    • M4100-26G-POE (GSM7226Pv1h1)
    • M4100-50G-POE+ (GSM7248Pv1h1)
    • M4100-26G-POE (FSM7226Pv1h1)
    • M4100-50-POE (FSM7250Pv1h1)
    • M4100-D12G (GSM5212v1h1)
    • M4100-D10-POE (FSM5210Pv1h1)
  • M7100 - firmware version 10.0.1.x
    • M7100-24X (XSM7224)
  • XSM7224S - firmware version 9.0.1.x
Last Updated:07/07/2025 | Article ID: 21578
Our team is here to help!
Phone
Chat
Email
