Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
You can reconfigure your system from X-RAID2 mode (the factory default mode) to Flex-RAID mode.
To change from X-RAID2 to Flex-RAID, follow these steps:
  1. If any data is stored on your system, back up your data.
    For more information, see the How do I back up data stored on my ReadyNAS Ultra series, Ultra Plus series, NVX Pioneer, or Pro Pioneer storage system? support article.
  2. Perform a factory reset reboot.
    WARNING!
    Setting your ReadyNAS system to its factory defaults erases all data and configuration settings.
    The process for performing a factory reset reboot varies by storage system.
    For more information, see the following support articles: During the factory reboot process, you have a 10-minute window to choose a RAID configuration. RAIDar sends a prompt to click the Setup button during this 10-minute time frame.
  3. Launch RAIDar, highlight your storage system, and click the Setup button.
    The ReadyNAS Volume Setup screen displays.
    If you do not select a format within 10 minutes, your system reboots in the same mode that it was previously using.
  4. Select the Flexible Volume (Flex-RAID) radio button.
  5. Select a RAID level from the Select the desired RAID level drop-down menu.
    If you select Auto, your ReadyNAS system automatically chooses a RAID level based on the number of disks that are installed in your system, as follows:
  6. Click the Next button.
    You are prompted to confirm the volume creation command.
  7. Click the OK button.
    The volume is formatted. This can take quite a while, depending on the size of your hard disk drives.
Last Updated:07/07/2025 | Article ID: 21241
Our team is here to help!
Phone
Chat
Email
