Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
This article applies to all Easy Managed Smart Switches with a traditional user interface (UI). For an article that applies to Easy Managed Smart Switches with an Easy Smart UI, see What are multicast and IGMP snooping and how do I configure these features on an Easy Smart Managed Switch using the Easy Smart user interface?
Multicast traffic is network traffic that is addressed to a group of IP addresses instead of to a single address. IP multicast is most often used for streaming media, such as video and voice over IP (VoIP). However, multicast traffic can slow your network by flooding all switch ports with all multicast traffic, even if the device connected to a particular port doesn’t care about the traffic or can’t do anything with it.
Internet Group Management Protocol (IGMP) snooping allows the switch to forward multicast traffic intelligently. Based on the IGMP query and report messages, the switch forwards traffic only to the ports that request the multicast traffic rather than to all ports. IGMP snooping helps to optimize multicast performance and is especially useful for bandwidth-intensive IP multicast applications such as online media streaming. Depending on the Easy Managed Smart Switch model, IGMP snooping is either enabled or disabled by default.
If you want to block even more multicast traffic and reduce your risk of a denial of service (DoS) attack, you can choose to block multicast traffic from unknown addresses. By default, traffic from unknown addresses is allowed.
In rare circumstances, such as when you are having trouble with a streaming application, you might want to turn off IGMP snooping temporarily or allow traffic from unknown multicast addresses.
To configure IGMP snooping and multicast on an Easy Managed Smart Switch using a traditional UI:
  1. Log in to a NETGEAR Easy Smart Managed Switch with a traditional UI:
    1. Connect your computer to the same network as the switch.
      You can use a WiFi or wired network connection, or connect directly to a switch that is off-network using an Ethernet cable.
    2. Launch a web browser.
    3. In the address field of your web browser, enter the IP address of the switch.
      For more information, see How do I access the device UI of my NETGEAR Easy Smart Managed Switch?
      The login page displays.
    4. Enter the switch password.
      The default password is password. The password is case-sensitive.
      The Switch Information page displays.
  2. Select System > Multicast.
  3. Select the IGMP Snooping Status Enable radio button.
  4. Enable or disable the blocking of unknown multicast traffic by selecting a radio button:
  • Enable: Select the Enable radio button. Unknown multicast traffic is blocked.
  • Disable: Select the Disable radio button. Unknown multicast traffic is allowed.
  1. Click the Apply button.
    Your settings are saved.
Last Updated:08/27/2025 | Article ID: 000068333
Our team is here to help!
Phone
Chat
Email
