Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
Insight bidirectional synchronization instantly updates the Insight cloud whenever you change settings through the device UI.
If a local change affects only the switch, Insight synchronizes the change immediately. If the change affects the entire Insight network configuration, Insight does not synchronize the change. Instead, Insight sends a notification indicating that the network-level configuration changed on a specific device. The next time the switch restarts, Insight overrides the local change with the network-level configuration.
This feature is available on the following Insight-managed Smart Switch models:
  • GS108Tv3
  • GS110TPv3
  • GS724TPv3
  • GS724TPPv3
  • GS728TPv3
  • GS728TPPv3
  • GS728TXv3
  • GS728TXPv3
  • GS728TXUPv3
  • GS752TPv3
  • GS752TPPv3
  • GS752TXv3
  • GS752TXPv3
  • GS752TXUPv3
  • MS108TUP
  • MS324TXUP
  • MS110TX
  • MS110TXUP
  • MS510TXUP
  • MS510TXM
  • XS508TM
  • XS516TM
  • XS724TM
  • XS748TM
The following settings can synchronize between Insight and the device UI of the switch:
  • Port Configurations
  • PoE Schedule
  • Port Mirroring
  • Static Routing
  • RADIUS Port Configuration
  • DHCP L2 Relay
  • DHCP Snooping
  • PoE Port Configuration
  • VLAN configuration and membership
  • Spanning-Tree
When the switch restarts, Insight network-level configurations override any changes you make through the device UI. The following settings are overwritten:
  • Location > Wired > Settings > Spanning Tree
  • Location > Edit Location > VLAN/Network Setup > Edit VLAN
  • Location > Edit Location > SNMP v1/v2
  • Location > Edit Location > SNMP v1/v2 >IP address
  • Location > Edit Location > SNMP v1/v2 > Community String
  • Location > Wired > Settings >DHCP L2 Relay > Global Configuration
  • Location > Wired > Settings > DHCP Snooping > Global Configuration
  • Location > Edit Location > Syslog Configuration
  • Location > Edit Location > Radius Server
  • Location > Edit Location > Routing
Last Updated:08/11/2026 | Article ID: 000066230
Our team is here to help!
Phone
Chat
Email
