Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
2 people found this helpful in last 30 days
Yes. You can create a separate SSID (network name) for the 2.4GHz wireless band and the 5GHz wireless band of your Nighthawk Mesh WiFi 6 products.
Using two SSIDs provides the following benefit:
  • You can connect slower or older devices to the 2.4GHz band. Since these devices don’t need a lot of bandwidth, the speed and performance of your 5GHz band is reserved for your high-speed devices.
To create separate 2.4GHz and 5GHz networks on your Nighthawk Mesh WiFi 6 products:
  1. Launch a web browser from a computer that is connected to your router’s WiFi network.
  2. Visit www.routerlogin.net.
  3. Enter the default user name and password.
    The default user name is admin. The default password is password.
    The BASIC page displays.
  4. Select the ADVANCED tab.
  5. Click Advanced Setup > Customize WiFi Network.
  6. Under the Customize Your WiFi- Create a separate 2.4GHz WiFi network section, select Customize 2.4 GHz WiFi Network.
  7. Enter a network name (SSID) for your 2.4GHz network.
  8. Select a security option for your 2.4GHz network.
    Note: We recommend keeping the security option and password the same for the 2.4GHz and 5GHz connections. This way, you can reconnect your devices and keep track of your network credentials.
  9. Repeat Steps 6-8 for the 5GHz network.
    Your separate 2.4GHz and 5GHz networks are active.
For more information:
Last Updated:07/07/2025 | Article ID: 000063027
Our team is here to help!
Phone
Chat
Email
