At the bottom of your NETGEAR access point there are wall-mounting holes. The distance between the holes is 4.125 in. (105 mm), center-to-center. It is recommend that you use M3 type screws, with a length of 0.75 inch (U.S.) or 20 mm (European).
To wall-mount your NETGEAR access point:
- As an option, create a template:
- Place a piece of white paper on the bottom of the access point, covering the wall-mounting holes.
- Use a pencil to gently scratch around the mounting hole areas.
- Tape the paper onto the wall where you want to mount the access point.
- Drill holes in the wall where you want to mount the access point.
If you created a template, drill the mounting holes at the center of the template circles.
The distance between the holes in the wall must be 4.125 in. (105 mm).
- Insert wall anchors in the holes.
- Insert screws into the wall anchors, leaving 3/16 in (0.5 cm) of each screw exposed.
- Align the access point’s wall-mounting holes with the screws and mount the access point so that the antennas are at the top.
Your access point is now mounted.
Last Updated:07/07/2025
Article ID: 000062621
