Enterprise AV Home WiFi Mobile Wifi Support Shop Deals
You can return your NETGEAR Orbi Pro WiFi 6 to its factory default settings. Use the end of a paper clip or a similar object to press and hold the Reset button located on the back of the Orbi Pro for at least seven seconds. The Orbi resets and returns to the factory default settings. For more information about the Orbi Pro WiFi 6 factory default settings, see your user manual.
Last Updated:08/02/2025 | Article ID: 000062273
Our team is here to help!
Phone
Chat
Email
